tcsh
    Lars Schylberg
    larss at lmv.lm.se
    Thu Jan 30 10:13:04 EST 1992
To all of you that are sitting with grass development everyday
I would like share a little goodie that I found last week.  It is
the the tcsh that is a public domain shell that is an addition to
csh.  It contains command line stack, editing, completion and lots
of other nice things.  This has only been availble for those have
had source code licence for unix before, but is now rewritten so that
you that don't need that.   It compiled nicely both on
our Apollo and Sun sparc machines.  I think you can find tcsh on most
bigger anonymous ftp machines.
This tcsh makes development of awk scritps much easier since you can
edit on the command line.
The only changes you have to make in Grass is to edit the
$GISBASE/etc/GIS.sh file a little like follows.
I have also modified the scripts to bring in personal aliases and set
up rm -r for everybody which I think is necesary.
Lars Schylberg
National Land Survey of Sweden           Dept. of Photogrammetry
R&D Departmant                           Royal Inst. of Technology
S-80112 Gavle, Sweden                    10044 Stockholm, Sweden
larss at lmv.lm.se                          larss at fmi.kth.se
Parts of GIS.sh
if test "$SHELL"
then
    if [ "$SHELL" = "/usr/local/bin/tcsh" ]
    then
	shell=tcsh
	shellname="TC Shell"
    fi
fi
things in between
This version running thru the $shellname ($shell)
Help is available with the command: g.help
When ready to quit enter:           exit
EOF
if [ $shell = csh ]
then
    HOME=$LOCATION
    export HOME
    cshrc=$HOME/.cshrc
    rm -f $cshrc
    echo "set home = $home" > $cshrc
    echo "set history=30 noclobber ignoreeof" >> $cshrc
# Added by Lars Schylberg, 910730 to bring all aliases into the GRASS shell
    if [ -r $home/.aliases ]
    then
	cat $home/.aliases >> $cshrc
    fi
    echo "alias rm 'rm -i'" >> $cshrc
    echo "set prompt='\\" >> $cshrc
    echo "Mapset <$MAPSET> in Location <$LOCATION_NAME>\\" >> $cshrc
    echo "GRASS 4.0 > '" >> $cshrc
    if [ -r $home/.grass.cshrc ]
    then
	cat $home/.grass.cshrc >> $cshrc
    fi
    if [ -r $home/.cshrc ]
    then
	grep '^ *set  *mail *= *' $home/.cshrc >> $cshrc
    fi
    if [ -r $home/.login ]
    then
	grep '^ *set  *mail *= *' $home/.login >> $cshrc
    fi
    $ETC/run csh
    HOME=$home
    export HOME
elif [ $shell = tcsh ]
then
    HOME=$LOCATION
    export HOME
    cshrc=$HOME/.cshrc
    rm -f $cshrc
    then
    fi
    then
    fi
    then
    fi
    then
    fi
    $ETC/run tcsh
    HOME=$home
    export HOME
else
PS1="
GRASS-GRID > "
    export PS1
    $ETC/run sh
fi
