v.db.rim questions
Prasanna Kumar Kondapaneni
prasanna at forestry.auburn.edu
Thu Jun 4 09:59:51 EDT 1992
Hello grass growers,
I posted the following questions to grassu-list a couple of
days ago. Since none of the users has replied, thought the programmers'
list might help. Here are the questions:
1. Here's my little problem:
I have a simple database with the following fields:
name type
label int
volume int
and other fields. What I'd like to do is, to set volume to some
value, say, 100 for all records with label = 5.
In the command line version, we can do this by making a query and
using the change command (with -l switch). Is there a way of
doing the same thing in the menu (interactive) version?
2. When I am using the cmd version, I can read attributes
from a vector map by using the .read_vect command with
a field name, e.g.,
.read_vect vector_map label <Enter>
It appears to me that we can't do this in the interactive version.
Is this true?
Thanks in advance,
-- Prasanna
