d.mon X Error
| I have just upgraded my DECstation 5000/200 from ULTRIX4.2 to ULTRIX4.2a and
| in the process I had to tar my grass system and then untar after the upgrade.
| After the upgrade I can't get d.mon to start an X window. I don't think its
| a problem with the ULTRIX upgrade but rather the tar and untar of the grass
| software (permissions or something). I believe this to be the case because
| none of my other X-window applications are acting differently, and d.mon had
| permission problems from the start.
nps!peter at cerl.cecer.army.mil
Fri Jun 19 17:05:24 EDT 1992
On my system (SunOS) tar doesn't handle pipes properly. You may just need to
recreate your pipe files in grass's dev directory with the mknod command:
mknod fifo.0a p
mknod fifo.0b p
mknod fifo.1a p
mknod fifo.1b p
mknod fifo.2a p
mknod fifo.2b p
etc.
chmod 666 fifo.*
Peter Strong -- National Park Service -- @cerl.cecer.army.mil:nps!peter
