format install.roff.ms
Marjorie Larson larson at zorro.cecer.army.mil
Thu May 28 18:59:54 EDT 1992
Try the following:
tbl install.roff.ms | troff -ms | lpr
we don't have any problems with it here using the above.  (Depending on
your setup, you may need to use the -t flag with your troff and lpr
commands, however.)
We do not have a postscript version of this file, but I'll suggest it to
someone and maybe they can put one out there shortly.  In the meantime,
I would try the above.
Marji Larson
USACERL
