oracle
Darrell McCauley mccauley at ecn.purdue.edu
Fri Aug 27 13:23:03 EDT 1993
Would this be useful to grass programmers?
I think that is was originally for moss.
from comp.infosystems.gis:
In article <9308251332.aa07492 at dsc.blm.gov>, Sol Katz 303-236-0101 <skatz at DSC.BLM.GOV> writes:
|> For those of you who have been waiting patiently for the C gis
|> code that stores spatial data in Oracle, your wait is over. For
|> a limited time only, the code is available over ftp.
|> You will find it at dsc.blm.gov cd ftp/pub/gis. named lgs.tar.Z
|> What you see is all that I have. I could not find any documentation in
|> digital form. The .PC extension indicates 'precompile'. Many of the
|> files with the .pc extension also have the same name with a .c
|> extension. These have been run though the Oracle pro-C program,
|> BUT there are many functions that are straight C, so don't blanket
|> delete them.
|> I was able, with a minimum of work, to modify the buffer program, so
|> that it read coordinates from an ascii file and wrote to an ascii file.
|> Generally the syntax begins with a GIS command name, followed by
|> GIS modifiers, followed by an Oracle select statement.
|> Note that the first and last points on a line are stored as nodes,
|> and not with the line (unless I'm wrong :-)    ).
|> sol--    (skatz at dsc.blm.gov -  phone 303-236-0101 - denver co. usa)
James Darrell McCauley            Dept of Ag Engineering, Purdue Univ
internet: mccauley at ecn.purdue.edu West Lafayette, Indiana 47907-1146, USA
bitnet: mccauley%ecn at purccvm      UUCP: pur-ee!mccauley
