xdigit runtime error -- Help needed
PoKung Lin
pklin at CERF.NET
Thu Dec 16 17:53:24 EST 1993
Hi, After compilation of xgrass on USL system, xdigit does not work and each
time when I key in xdigit under grass prompt, I will get following error
msgs:
X Error of failed request: BadValue(integer parameter out of range
for operation)
Major opcode of failed request: 53 (X_CreatePixmap)
Value in failed request: 0x0
Serial number of failed request: 413
Current serial number in output stream: 415
Can any experienced X-Window friends might pass me some hint? Where the bugs
will be?
Thank you for any help
PK Lin
E-mail pklin at cerf.net
Tel: (617) 942-1655
