xdigit runtime error -- Help needed
Jim Pirzyk
pirzyk at cerl.cecer.army.mil
Fri Dec 17 10:33:17 EST 1993
In info.grass.programmer you write:
If you find out what caused this, I would like to know. I get the same
error running xgrass on Solaris 2.x, but I get it when I try to start xdigit.
>Hi, After compilation of xgrass on USL system, xdigit does not work and each
>time when I key in xdigit under grass prompt, I will get following error
>msgs:
> X Error of failed request: BadValue(integer parameter out of range
> for operation)
> Major opcode of failed request: 53 (X_CreatePixmap)
> Value in failed request: 0x0
> Serial number of failed request: 413
> Current serial number in output stream: 415
[Jim] pirzyk at uiuc.edu ------------------------------------------- __o
TAC & GrassNet System Administrator, US Army Corps of Engineers _'\<,_
Construction Engineering Research Laboratories, Champaign IL USA (*)/ (*)
