Compiling Xgrass under SunOs4.1.3
Brett Hazen
hazen at cs.utk.edu
Fri Jul 16 13:14:05 EDT 1993
For some reason I am having trouble compiling Xgrass
on a Sparc-10 with Motif 1.2.1. I get the following
output:
/usr/users/hazen/install/grass/src/src/xgrass/libes/Xgi
make -f OBJ/make.rules
rm -f OBJ/Matrix.o
cc -O -D_NO_PROTO -I/usr/include/Xm -I/usr/include/X11 -I/usr/users/hazen/insta
ll/grass/src/src/include -c Matrix.c
/usr/users/hazen/install/grass/src/src/include/Matrix.h: 121: XmRStringArray red
efined
"/usr/users/hazen/install/grass/src/src/include/MatrixP.h", line 252: syntax err
or at or near variable name "XmManagerClassPart"
"/usr/users/hazen/install/grass/src/src/include/MatrixP.h", line 415: syntax err
or at or near variable name "XmManagerPart"
"Matrix.c", line 75: matrix undefined
"Matrix.c", line 153: warning: undeclared initializer name XmManagerRec
"Matrix.c", line 153: syntax error at or near symbol )
"Matrix.c", line 154: syntax error at or near type word "char"
"Matrix.c", line 486: warning: undeclared initializer name xmManagerClassRec
"Matrix.c", line 547: too many initializers
"Matrix.c", line 575: too many initializers
"Matrix.c", line 575: fatal error: too many errors
*** Error code 1
make: Fatal error: Command failed for target `OBJ/Matrix.o'
Current working directory /usr/users/hazen/install/grass/src/src/xgrass/libes/Xg
i
*** Error code 1
make: Fatal error: Command failed for target `all'
GISGEN failure at STEP: src/xgrass/libes
Any suggestions?
Brett Hazen hazen at cs.utk.edu | "Wo wohnen die Deutsche?", fragt
2521 Kingston Pike #2005 | einer. "In Deutschland", antwortet
Knoxville, TN 37919-3318 USA | der andere. "Und die Amis?"
Telephone: +1 615 673 3226 | "In Amiland, natuerlich!"
