No subject
Net.Noise owner
news at max.cecer.army.mil
Wed Jun 2 10:53:50 EDT 1993
Newsgroups: info.grass.programmer
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: v.in.ascii summary
Message-ID: <C801Do.EHJ at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <199305211600.AA01518 at access.digex.net>
Date: Wed, 2 Jun 1993 14:53:48 GMT
Lines: 62
In <199305211600.AA01518 at access.digex.net> zhuang at access.digex.net (Xin Zhuang) writes:
>I had asked our grass group for a help on
>v.in.ascii. I run the following:
> v.in.ascii
> v.support
> v.to.rast
> r.support.
>But I got a layer with one category only.
>I was told I had to use v.digit if I didn't
>had the coressponding dig_att, which is true.
>However, v.digit is kind of tedious. SO I created
>a dig_att file. I still got the same as
>what I got without dig_att. So I dived into
>v.in.ascii (in src/mapdev/v.in.ascii) and found
>the following, which I think it's a bug:
>>>>code from v.a_b_dig.c<<<
> char file1[300], file2[300];
> G__make_mapset_element( "dig_att");
> if (0 ==access (file1, 0))
> G__file_name (file1, "dig_att", old->answer, mapset);
> G__file_name (file2, "dig_att", new->answer, G_mapset());
> cp_file (file1, file2);
>>>>modified code<<<
>>>>end of code<<<
>Before I report to grass as a bug, I would apprecite if someone
>give a double check.
>Go back and look at the code listed above, I think you would
>agree on what I modified. It's so costly. It took me a few
>hours to come to this point. I'd like to share with everyone
>in the grass group.
Yes, this is a bug. The fix looks right, too. Please report it.
Michael Shapiro shapiro at zorro.cecer.army.mil
U.S. Army CERL (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
