No subject
Net.Noise owner news at max.cecer.army.mil
Wed Jun 2 10:57:38 EDT 1993
Newsgroups: info.grass.programmer
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: d.3d in GRASS 4.1
Message-ID: <C801K0.EL4 at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9305281928.AA13006 at towhee.cor2.epa.gov>
Date: Wed, 2 Jun 1993 14:57:36 GMT
Lines: 30
In <9305281928.AA13006 at towhee.cor2.epa.gov> greg at towhee.cor2.epa.gov (Greg Koerper) writes:
>	d.3d, though faster, is now brain dead.
>1) The format of 3dview files is different.  It no longer retains information
>about erase colour, line colour, or average elevations.  This must be
>changed EACH time a 3dview file is used.
>2) It will over-write an existing 3dview file when it uses an old one.
>3) It (still) will not allow me to over-write an existing 3dview file when
>I exit d.3d.  So it can do what it will not allow me to do.
>4) It will draw into the full screen frame, even it a sub frame is active.
>5) It will do item 4 only AFTER the first time an old 3dview file is used.
>Then there is different behaviour between the first use of a 3dview file
>from all following uses.  This is difficult to reproduce.
>	I have not tried it on an lat/long projections yet, so I do not know
>if it is still broken in that way.
Please send bug reports to grassbug at zorro.cecer.army.mil. Posting them to
these forums doesn't ensure that they get into the bug tracking process at
OGI.
Michael Shapiro               shapiro at zorro.cecer.army.mil
U.S. Army CERL                (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
