g.gnuplot "help" - I did that!
Anantha Prasad
prasad at landcover.inhs.uiuc.edu
Fri Jun 18 14:39:11 EDT 1993
After you compiled the gnuplot into the Grass binary dierectory,
Did you do the following?
% cd whatever/gnuplot/docs
% make gih
% mkdir $(GISBASE)/man/helpp
% cp whatever/gnuplot/docs/gnuplot.gih $(GISBASE)/man/helpp
Then rerun Grass (if you are already in grass get out and start it again)
and try help in g.gnuplot. If this does'nt work, check permissions for
the help file. If it still does'nt work, I am stumped!! Prasad
