Cancelling Xgrass windows
Joe Plesha
root at dagwood.cr.usgs.gov
Mon Mar 1 22:12:48 EST 1993
HI there,
Well I did figure out a couple of things that might be of help to you.
Some of the calls which were commented out in your compile
were X11R5 calls. So the reason things don't work may be because
the code was meant for X11R5. Now that I've changed to X11R5 I've had
to recompile some X programs so that they don't core dump when I use
them. You might have to wait until you get you get HPUX 9.0 with X11R5.
As we speak (me typing) I am busy compiling grass4.1beta with the
ansi c compiler. I'll let you know if it works.
S
S Joe Plesha
S jplesha at bgdem1.cr.usgs.gov
S root at bgdem1.cr.usgs.gov
__
/ \ HOME OF GRASS
/ \ ON THE
------------------- HP 9000 Series 300/400/700/800
| ___ ___ |
| |o| |o| | HP 9000/385 HPUX 9.0
| | | bgdem1.cr.usgs.gov |
| GRASS | | (136.177.80.2) |
| HP 9000 | | U.S. Geological Survey |
| ____ | | Branch of Geophysics |
| | | | | Electromagnetic Studies |
| | .| | | Denver, Colorado |
| |__| | ----------------------------
------------------- anonymous FTP site (24 hours a day)
