No subject
Net.Noise owner
news at max.cecer.army.mil
Fri Mar 12 09:25:52 EST 1993
Newsgroups: info.grass.programmer
Path: vinny.cecer.army.mil!pirzyk
Subject: Re: GRASS on SUN SPARC Classic
Message-ID: <C3s5F2.Jwn at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9303111109.AA09706 at emma.ruc.dk> <9303120335.AA15000 at cocklebur.ecn.purdue.edu>
Date: Fri, 12 Mar 1993 14:25:50 GMT
Lines: 32
In <9303120335.AA15000 at cocklebur.ecn.purdue.edu> mccauley at ecn.purdue.edu (Darrell McCauley) writes:
We have tried to run grass under Solaris 2.0 and it *DOES NOT WORK* even though
sun says that it will. From what I have herd Sun say is that it *MIGHT* work,
if it does not do these:
* Pretend that there is a long list of stuff which I cannot remember *
>*supposedly* binaries will run under SunOS 5 if they
>were compiled with dynamic linking under 4.1.x.
>from comp.sys.sun.admin FAQ:
>> 47) Will SunOS 4.1.x binaries run under SunOS 5.x?
>> Yes they will, with some restrictions. The most significant is
>> that the binary in question must have been "dynamically linked."
>> Otherwise, you will get the message
>> Bad system call (core dumped)
>> immediately when starting the 4.1.x binary on SunOS5.
>> Also, bear in mind that there is a performance overhead for
>> this "binary emulation"; each system call happens twice,
>> once to trap into the emulation mode and again to get from
>> there into the UNIX kernel.
[Jim] pirzyk at uiuc.edu ------------------------------------------
TAC & GrassNet System Administrator, US Army Corps of Engineers
Construction Engineering Research Labratories, Champaign IL USA
