Lambert Azimuthal Equal Area
Anne Gisiger
anne at cast.uark.edu
Wed Mar 31 17:01:27 EST 1993
Hello
I have vector layers in the Lambert Azimuthal Equal Area projection that I
need to use in GRASS.
Does anyone know if GRASS can deal with this projection i.e.:
- is it possible to create a Lambert Azimuthal location, and
- could layers in any of GRASS predefined projections be
transformed into Lambert Azimuthal using v.proj?
I was told that GRASS used to allow the creation of user-defined ellipsoids?
If it is still possible it might be a solution to my problem. Do you have
any ideas about how it is done?
Anne Gisiger, Research Assistant FAX: (501) 575-3846
CAST, Center for Advanced Spatial Technologies TEL: (501) 575-6159
12 Ozark Hall, University of Arkansas
Fayetteville AR 72701 anne at cast.uark.edu
