4.1 compile failure:
Martin Ameskamp
ma at informatik.uni-kiel.dbp.de
Fri May 14 13:26:42 EDT 1993
> I had one other rather strange event I haven't tracked down yet. I used
> setup in a normal fashion, but it failed to place the -I flag for the
> compiler as a prefix for $XMINCPATH, the Motif include path. This brought
> the XGRASS compilation to a halt. I manually edited the file CMD/head/sun4
> to patch the Gmakefile problem, but I haven't had time to explore the setup
> script yet to figure out what happened.
> Anyone have a similar event?
Yep, same happened to me (on HP UX 8.05, gcc 2.3.3)
There are also one or two problems with other xgrass modules:
in src/xgrass/libes/Xgi/Interact.c, line 491, our X release
didn't know about XtInheritFocusMovedProc, changing from
Xt to Xm made it compile (haven't run it yet). Is that specific
to HP (Motif 1.1)?
Also, when trying to link xgrass4.1.exe, I get the unsatisfied
symbol _XtGetCallbackList. This is declared as an external function
and used in src/xgrass/libes/Xgi/Help.c (lines 1033 & 1041 resp.).
It is defined on our Suns and even SCO UNIX knows about it, but
HP (grumble...). Any ideas what to do? Is it really necessary?
Martin
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 2300 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma at informatik.uni-kiel.dbp.de
