help with compile error
Darrell McCauley mccauley at ecn.purdue.edu
Fri May 14 17:38:04 EDT 1993
Timothy Keitt (tkeitt at algodones.unm.edu ) writes on 14 May 93:
>ld: -lXm: No such file or directory
>XMLIBPATH           = -L/usr/local/motif/lib
>XMLIB               = -lXm
look in /usr/local/motif/lib for libXm*
if it's not there, then you're missing the motif library.
complain to your sys admin.
