GRASS modeling
Darrell McCauley mccauley at ecn.purdue.edu
Tue Oct 5 12:21:13 EDT 1993
Shen Lu (slu at titania.rutgers.edu) writes on 5 Oct 93:
>The on-line manual entry for r.mapcalc does make reference to if
>statements, but it does not elaborate.  Presumably, I can write a
There should be a reference to the r.mapcalc tutorial (I didn't
check - maybe there is, maybe there isn't).
>script that invokes a series of GRASS commands, any one of which may
>be in a loop.  Any help on how to do this, on the extent of
just as you would do in normal script programming.
For example, in csh:
foreach file ($LOCATION/cell)
  d.rast $file:t
  sleep 10
end
>programming functions available in GRASS, and on how to get real time
>displays of model results would be appreciated.
>  Please reply to :   slu at titania.rutgers.edu
