HPXL300 driver
Darrell McCauley
mccauley at ecn.purdue.edu
Thu Oct 7 07:56:21 EDT 1993
Anabel Donadios (anabel at tilo.datsi.fi.upm.es) writes:
>This command is a shell script:
Anabel, it looks as though you may have to change this script.
(This script was written for BSD and is not Sys V friendly).
>#!/bin/sh
below may be 'uname' in other cases. This *should* be
dir=`g.tempfile pid=$$`
>dir=$LOCATION/.tmp/`hostname`
lp -dpj -oraw -onb $outfile
> lpr -s -Ppj $outfile
>the next message error appear:
>/usr/bin/lpr: option -Ppj not recognized
>And it's right because the -P option is not recognized for lpr script.
>Usually we use
> lp -dlpc -oraw -onb name_file
>but I can't print either.
