Cannot get ltplus to run
James A. Farley
jim at cast.uark.edu
Wed Oct 13 11:42:12 EDT 1993
Bob Atnip writes:
> I'm having trouble with ltplus. The files "ltpgo & ltplus" were located in my
> /home/atterbury/grass/4.1/ltp/bin directory. When I tried to type ltpgo I got the error message "No such command '/usr/local/ltp/bin/ltplus'". I copied the
> "ltpgo & ltplus" files to /usr/local/ltp/bin directory, then when I typed
> ltpgo I got the message:
> setting internal variables: paths.h
> from: /usr/local/ltp
> Welcome to Line Trace Plus.
> Version 2.22 Dabritz/Jonson/Martin,
> Loading lookup tables. Done.
> Loading configuration variables.
> error in initialize: get_config failed to execute.
> Line Trace Plus terminating.
In order for ltplus to execute correctly the following directories need to
be at the same level as the bin containing ltplus, ltpgo:
bin dictionary ibm map_lists
config digitizers incl maps
cursor_keys digmenus macros menus
dictionaries export make_links pens
These directories are found under src.related/LTPLUS after compilation. I believe
the problem you are encountering has to do with the code locating the dir config.
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim at cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
