LOCAL delivery error
Local delivery agent Postmaster at bgcict.bitnet
Sun Feb 6 15:55:53 EST 1994
Note: this message was generated automatically.
The following error(s) occurred during local delivery of your message.
Error in delivery to user RSGISBG:
    retry count exceeded
Message follows.
Received: from UIUCVMD (MAILER) by bgcict.bitnet (MX V3.1) with Jnet; Thu, 03 Fe
b 1994 17:53:51 +0200
Return-Path: <@VMD.CSO.UIUC.EDU:grass-lists-owner at MAX.CECER.ARMY.MIL>
Received: from UIUCVMD (NJE origin SMTP at UIUCVMD) by VMD.CSO.UIUC.EDU (LMail V1.1
d/1.7f) with BSMTP id 3732; Thu, 3 Feb 1994 08:34:51 -0600
Received: from max.cecer.army.mil by vmd.cso.uiuc.edu (IBM VM SMTP V2R2) with TC
P; Thu, 03 Feb 94 08:34:42 CST
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA15112 (
5.67a/IDA-1.5 for <rsgisbg at BGCICT.BITNET>); Thu, 3 Feb 1994 10:24:29 -0600
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id AA089
96; Thu, 3 Feb 94 08:17:46 CST
Received: from zorro.cecer.army.mil by max.cecer.army.mil with SMTP id AA15061 (
5.67a/IDA-1.5 for <grassp-people at max.cecer.army.mil>); Thu, 3 Feb 1994 10:19:49
-0600
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA01295
 (5.67a/IDA-1.4.4 for <grassp-people>); Thu, 3 Feb 1994 08:17:43 -0600
90; Thu, 3 Feb 94 08:17:40 CST
Received: from niwot (niwot.CFNR.ColoState.EDU) by max.cecer.army.mil with SMTP
id AA15057 (5.67a/IDA-1.5 for <grassp-list at max.cecer.army.mil>); Thu, 3 Feb 1994
 10:19:43 -0600
Received: by niwot (4.1/SMI-DDN) id AA21197; Thu, 3 Feb 94 07:17:37 MST
Date: Thu, 3 Feb 1994 07:17:37 MST
Message-ID: <9402031417.AA21197 at niwot>
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassp-list at max.cecer.army.mil
Precedence: Bulk
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassp-list at moon.cecer.army.mil.
Precedence: Bulk
Subject: Re: ALTEK DIGITIZER DRIVER
Newsgroups: info.grass.programmer
In-Reply-To: <199402022132.NAA13465 at nic.cerf.net>
Organization: College of Natural Resources, Colo. State Univ.
CC:
In article <199402022132.NAA13465 at nic.cerf.net> you write:
>Hi there,
>       I am wondering if anyone use ALTEK DIGITIZER with AC31 controller on
>GRASS4.1. I got the problem to let this beast communicate well with v.digit.
>       I checked the hardware connection and it's okay. The configuration
>file under $GISBASE/etc/digitizers that I used is al30f8_16. I talked with
>               Thank you in advance.
>                               PK Lin
>                               E-mail: pklin at cerf.net
>                               Tel:(617)942-1655
PK -- We have the same setup, running GRASS4.1 on a SPARCclassic with
Solaris 2.2:  and no v.digit.  We have had to keep an old workstation
(SUN 386i) active runnig GRASS4.0 & SunOS 4.0.2 in order to run the
digitizer.  This subject was brought up before on the lists, but never
resolved.  I'm not sure if it is a SOLARIS 2.x problem or a GRASS 4.1
problem.
v.digit runs like a DOG in "no digitizer" mode, something to do with
the fifo's and SOLARIS, I've been told.  Does your v.digit run without
the digitizer?
Also, I think v.digit was changed in GRASS4.1, and there is a "v.digit2" or
"v.digit.old" code around which is the GRASS4.0 v.digit -- can anyone
shed some light on this?  Has ANYONE got an ALTEK AC31 running WELL on
GRASS4.1?
Ronald Thomas                                ront at meeker.cfnr.colostate.edu
 Natural Resource Spec. (GIS)         ^^^    Phone: 303-586-3565  x285
  Resources Management Division  ^^  ^^^^^   FAX: 303-586-4702
   Rocky Mountain National Park ^^^ ^^^^^^^  Estes Park, CO  80517
("Damn it Jim, I'm a GIS Specialist, not computer hacker -- just give me a
tool that work!!"  "Sorry, Bones, Star Fleet is cheap, deal with it.")
