LOCAL delivery error
Local delivery agent Postmaster at bgcict.bitnet
Sun Feb 6 15:56:13 EST 1994
Note: this message was generated automatically.
The following error(s) occurred during local delivery of your message.
Error in delivery to user RSGISBG:
    retry count exceeded
Message follows.
Received: from UIUCVMD (MAILER) by bgcict.bitnet (MX V3.1) with Jnet; Thu, 03 Fe
b 1994 18:07:05 +0200
Return-Path: <@VMD.CSO.UIUC.EDU:grass-lists-owner at MAX.CECER.ARMY.MIL>
Received: from UIUCVMD (NJE origin SMTP at UIUCVMD) by VMD.CSO.UIUC.EDU (LMail V1.1
d/1.7f) with BSMTP id 4726; Thu, 3 Feb 1994 09:09:21 -0600
Received: from max.cecer.army.mil by vmd.cso.uiuc.edu (IBM VM SMTP V2R2) with TC
P; Thu, 03 Feb 94 09:09:14 CST
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA15959 (
5.67a/IDA-1.5 for <rsgisbg at BGCICT.BITNET>); Thu, 3 Feb 1994 11:07:30 -0600
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id AA090
29; Thu, 3 Feb 94 08:50:00 CST
Received: from zorro.cecer.army.mil by max.cecer.army.mil with SMTP id AA15733 (
5.67a/IDA-1.5 for <grassp-people at max.cecer.army.mil>); Thu, 3 Feb 1994 10:52:02
-0600
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA01546
 (5.67a/IDA-1.4.4 for <grassp-people>); Thu, 3 Feb 1994 08:49:56 -0600
23; Thu, 3 Feb 94 08:49:52 CST
Received: from uafhp.uark.edu by max.cecer.army.mil with SMTP id AA15727 (5.67a/
IDA-1.5 for <grassp-list at max.cecer.army.mil>); Thu, 3 Feb 1994 10:51:52 -0600
Received: from cast.uark.edu by uafhp.uark.edu with SMTP (1.37.109.4/15.6) id AA
15053; Thu, 3 Feb 94 08:47:35 -0600
Received: by cast.uark.edu (4.1/SMI-4.1) id AA15154; Thu, 3 Feb 94 08:56:27 CST
Message-ID: <9402031456.AA15154 at cast.uark.edu>
Subject: Re: ALTEK DIGITIZER DRIVER
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassp-list at max.cecer.army.mil
Precedence: Bulk
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassp-list at moon.cecer.army.mil.
Precedence: Bulk
Date: Thu, 3 Feb 1994 8:56:26 CST
In-Reply-To: <9402031417.AA21197 at niwot>; from "Ronald Thomas" at Feb 3, 94 7:17
am
X-Mailer: ELM [version 2.3 PL11]
> In article <199402022132.NAA13465 at nic.cerf.net> you write:
> >Hi there,
> >     I am wondering if anyone use ALTEK DIGITIZER with AC31 controller on
> >GRASS4.1. I got the problem to let this beast communicate well with v.digit.
> >     I checked the hardware connection and it's okay. The configuration
> >file under $GISBASE/etc/digitizers that I used is al30f8_16. I talked with
> >             Thank you in advance.
> >                             PK Lin
> >                             E-mail: pklin at cerf.net
> >                             Tel:(617)942-1655
> PK -- We have the same setup, running GRASS4.1 on a SPARCclassic with
> Solaris 2.2:  and no v.digit.  We have had to keep an old workstation
> (SUN 386i) active runnig GRASS4.0 & SunOS 4.0.2 in order to run the
> digitizer.  This subject was brought up before on the lists, but never
> resolved.  I'm not sure if it is a SOLARIS 2.x problem or a GRASS 4.1
> problem.
> v.digit runs like a DOG in "no digitizer" mode, something to do with
> the fifo's and SOLARIS, I've been told.  Does your v.digit run without
> the digitizer?
> Also, I think v.digit was changed in GRASS4.1, and there is a "v.digit2" or
> "v.digit.old" code around which is the GRASS4.0 v.digit -- can anyone
> shed some light on this?  Has ANYONE got an ALTEK AC31 running WELL on
> GRASS4.1?
> Ronald Thomas                                ront at meeker.cfnr.colostate.edu
We run GRASS4.1 on SunOS4.1.3 on IPC's, IPX's Sparc 1+'s, Sun 690, etc.
The following settings on our Altek AC31 controller work fine with v.digit
(v.digit2 is the 4.0 version):
>     S1    S2    S3     S4
>    0 1   0 1   0 1    0 1
> 1  x     x       x      x
> 2  x     x     x        x
> 3  x     x       x      x
> 4  x     x       x    x
> 5  x       x     x    x
> 6    x   x     x      x
> 7  x     x     x        x
> 8  x     x     x        x
> We are using the al30f8_16 digitizer driver in our digcap file.
> This setup works for us on a Sun IPC and a Sun Sparc 1+. Good luck!
Why am I dreading the switch to Solaris 2.x ?!!
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
