problems with xdigit and MOTIF 1.2.2 on LINUX
Andreas Holz (CIP guests)
asholz at cip.informatik.uni-erlangen.de
Mon Jan 10 12:14:48 EST 1994
Hello GRASS Programmers,
here some more specific informations on my problem with
xdigit on MOTIF 1.2.2 and LINUX.
Here a reduced call path:
... some calls before
make_custom_menu (custmenu, parent); in panel.c
-> make_custom_menu (parent, top) in custommenu.c
... some other calls
-> cmenu=make_colors_menu(paremt) in xcolor.c
If I put comments around the call of make_colors_menu(..) xdigit
comes up an runs. The only problems is, if I load a vector dataset, place
a window on top of xdigit, or close a dialog box of xdigit, the region,
which was covered by the overlaying window becomes white (how to solve this
problem)!. I can clear this white region only by moving xdigit over
the screens border.
If I compile xdigit with the call of make_colors_menu(..), there are
several lines, which will cause an X-error during startup of xdigit:
1. line 123
btns[i] = XtCreateManagedWidget (names[i], xmPushButtonWidgetClass, colorform, wargs, n);
names[i] contains the name of a bitmap defined in make_bitmaps.c
colorform is a ManagedWidget created in line 93
wargs is defined in several lines above line 120, the pixmap returned with XmGetPixmap
seems to be valid, but this entry causes the crash! If I change it to NULL (n=0),
there will be no error at this line
2. line 132
labels[i] = XtCreateManagedWidget (" ", xmLabelWidgetClass, colorform, wargs, n);
causes the next X-error
3. line 178
currcolor = XtCreateManagedWidget (" ", xmLabelWidgetClass, colorform, wargs, n);
I hope, thats all for the moment.
It is a little bit peculiar, because similar calls to XtCreateManagedWidget in other modules seems
to work properly, but what is the problem with xcolor.c.
PS. GRASS Version: 4.1
Updates: 1, 2 and 3
OS: Linux
Kernel: 99pl14
Libc: 4.4.4
X-Server: XFree86 2.0
Who is able to help?
Is it possible to contact the author of xdigit (xcolor.c) directly?
PPS. See my previous mails, there are others, who have the same problem, also on different os
an machines!
Dipl. Geol. Andreas Holz email: asholz at cip.informatik.uni-erlangen.de
Institut fuer Geologie und Mineralogie
Schlossgarten 5
91054 Erlangen
GERMANY
