Motif 1.2.x & X11R5
Joe Plesha
root at bgdem1.cr.usgs.gov
Mon Jan 10 12:52:51 EST 1994
Hello,
I don't know where everyone is on the discusion of XGRASS and compiling
it under Motif 1.2.x and X11R5. As far as I know the compile of XGRASS was
meant for X11R4 & Motif 1.1. Every machine we haved tried it on with X11R5
and Motif 1.2.x has failed with modification to a couple of Xt calls
and the header files to several routines in the XGRASS library directories.
the change from Motif 1.1 to Motif 1.2 was a major one. I'm not expecting
to get XGRASS to function properly without some help from CERL. Andreas
I was wondering what changes were made to the code you made to get XGRASS
to compile? The manage widget is a problem since some of the calls changed
between Motif versions. I've tracked down some of my problems but when I get
to the widget level I start to assume that the error is embedded in the
library routines and how they function between versions of Motif. I think
it will take the original programmer to figure out the problem since they
know the code and what is expected of the widget.
Joe Plesha
jplesha at bgdem1.cr.usgs.gov
__________________________________________________________________________
| HOME OF GRASS ON HP9000s | HP 9000/385 HPUX 9.0 |
| U. S. Geological Survey, BGP | bgdem1.cr.usgs.gov (136.177.80.2) |
| Electromagnetic Studies | Phone: (303) 236-1398 |
| Denver, Colorado 80225 | Anonymous FTP site for HP GRASS |
