grass4.0/grass3.0 color tables
Malcolm Williamson
malcolm at cast.uark.edu
Wed Jan 12 12:22:00 EST 1994
Jerry Ballard writes:
> Does anyone have or know of a utility program that converts
> GRASS4.0 color tables back into the old GRASS3.0 color table
> format?
> I'm trying to display GRASS layers in ARC-INFO (gasp! Can I say
> that word on this list?) and it appears that the ARC-INFO image
> command can only display GRASS layers that have the old color table
> format.
Can't help you with converting one to the other, but imagegrid *will* read
GRASS4* files if you move or delete the GRASS color table. Also, remember to
uncompress the raster data (r.compress -u). You'll have to either create your
own color table in grid or use a stock one.
Regards,
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
