Concurrent d.rast
Davide Frisoni
frisoni at faw.uni-ulm.de
Wed Jul 6 11:36:25 EDT 1994
In article <9407050852.AA02085 at itd0.dsto.gov.au>, you write:
|> I have a problem trying to display graphics to several monitors simultaneously.
|> What I have done is started a number of monitors, and then written a script
|> which contains instructions like:
|> d.mon select=x0
|> d.rast <map1>&
|> d.mon select=x1
|> d.rast <map2>&
|> etc
|> Each 'd.rast' command spawns a separate process, but these seem to interfere
|> with each other, with the result that some monitors wind up blank. Questions:
|> (a) Am I trying to do something which the X driver does not support? I have
|> noticed that most demo scripts write to graphics monitors in a sequential
|> fashion (still on release 4.0, btw)
|> (b) What happens if different users, on different X terminals, all try to
|> display at once - do they receive concurrent or sequential service?
|> Conn V Copas
|> Information Technology Division
|> Defence Science and Technology Organisation
|> PO Box 1500
|> Salisbury tel: +61 (0)8 25 95349
|> SA 5108 fax: +61 (0)8 25 96781
|> Australia e-mail: cvc at itd.dsto.gov.au
I've tried the follow:
d.mon start=x0
g.region region=<1^region>
d.mon start=x1
g.region region=<2^region>
d.mon sel=x0
d.mon sel=x0;d.rast <1^map>&;d.mon sel=x1;d.rast <2^map>&
it works 'fine' and concurrently with different region setted!
I've surrounded the word fine because sometimes a location error occurs (I used maps in
different mapset).
I Hope this help you.
good luck,
--FRY
. __
| _| ==============================================================
|_/\ / Davide Frisoni | e-mail(internet):
\ o| Forschungsinstitut fuer anwendungs- | frisoni at faw.uni-ulm.de
_ | \ orientierte Wissensverarbeitung-FAW |
| | \ \ Helmholzstr. 16 | Tel.: +49-731-501.8626
|_| \ \ D-89081 Ulm, Germany | FAX: +49-731-501.929
\ _\ ==============================================================
____ /_/
\._/
