No subject
Alec sergeyva at archimedes.acf.nyu.edu
Tue Jul 19 22:27:43 EDT 1994
	Hi.
	I tried to compile C-code of my application under IRIX5.2 using
	the same Gmakefile and environment variables as used before
	under IRIX4.x.  Compiler created all object files, but ld
	gave the following Error message:
ld:
Object file format error in:
/Users1/lopresti/sergeyva/grass/src/libes/LIB.sgi/
libvect.a(open.o): cannot mix Elf and COFF objects.
*** Error code 1 (bu21)
	Could you, please, tell me what Elf and COFF objects are, and
	what should be fixed in that situation?
	-Vitaly Brukhman
