using CELL monitor
Malcolm Williamson
malcolm at cast.uark.edu
Thu Jul 28 10:43:25 EDT 1994
> To be able to create high resolution (2000 x 2666) PostScript output to a
> slidewriter, I uncommented the lines pertaining to the CELL monitor in
> the monitorcap file and inserted CELL_HEIGHT and CELL_WIDTH values into
> my .grassrc file. I then started the CELL monitor, set the region to
> contain a very high number of cells, and issued display commands for
> several map layers. Stopping the CELL monitor, I expected the newly
> created raster map layer D_cell to have a 2000 x 2666 size, but it
> didn't. It was only 640 x 480 cells in size. I suspect this must have
> been hardwired in the CELL driver. Can anyone confirm this and supply a
> method of changing these values?
> P. Martijn van Leusen
> Institute of Prehistory, University of Amsterdam martijn at scanner.frw.uva.nl
Martijn,
The variables in .grassrc are not automatically exported to your environment.
You can either set these environmental variables manually ( setenv CELL_HEIGHT
2666, etc., if you are running csh), or have them set automatically by
creating a .grass.cshrc file in your home directory with these variables
added to it (normally, copy your standard .cshrc to .grass.cshrc and edit it).
Regards,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
