Recompilation of Xgen under IRIX5.x
Alec sergeyva at archimedes.acf.nyu.edu
Thu Jul 28 18:03:24 EDT 1994
	I participate in recompiling Xgen under IRIX5.x.  We run into the
	following problem::
        In xgen/src/Setup (at line 773), configuration process
        looks for an X11 lib file
>>x=`./loc libX11.a libX11.a $xlibpth`
>>if test -f "$x"; then
        I've checked both on the system and the original Irix 5.2
        distribution CD but no such library exists under "x_eoe".
        Do you know what the get around for this is ?
        Thanks in advance.
        -Vitaly
