New version of interpolation library
Irina K. kosinov at uxa.cso.uiuc.edu
Mon Jun 27 16:20:25 EDT 1994
This is my THIRD try to post this message
I have installed the new version of interpolation library on
moon.cecer.army.mil under /grass/incoming/interp_lib_new.shar.Z
It contains some bug fixes :mask option now works and
the program doesn't get killed anymore for hundreds of thousands points.
It also has a new version of r.resample.tps which is to replace the
not-library version.
To install:
1) uncompress interp_lib.shar.Z
2) sh interp_lib_new.shar
This creates 5 directories -- tree/, data/, interp/, s.surf.tps/,
v.surf.tps/ and r.resample.tps.
3) run gmake4.1 in tree/ and data/
4) run gmake4.1 in interp/
5) run gmake4.1 in the programs' directories
Note: the binaries go to BIn_CONTRIB_CMD so the s.surf.tps binary is
called s.surf.2d in order to avoid replacing 4.1 s.surf.tps version.
Write me if there are any question
Irina
