HPLaserJet 4M and MAPGEN
Gerald I. Evenden
gie at charon.er.usgs.gov
Thu Sep 8 21:50:18 EDT 1994
>Date: Thu, 8 Sep 1994 12:51:53 -0700
>From: PoKung Lin <pklin at CERF.NET>
>Sender: grass-lists-owner at max.cecer.army.mil
>Reply-To: grassp-list at max.cecer.army.mil
>Subject: HPLaserJet 4M and MAPGEN
>Hi everyone,
> I have a HPLaserJet 4M laser printer and want to connect
>it to SCS GRASS-MAPGEN4.1 interface. To do so, I first change
>the code in the file SCS/plotter/devlist.c to add one line:
> "laser", Dpstscr, 0, "PostScript printer",
>in the initilization dev_list[], since my printer is named as
>"laser" by system administrator. It looks like following:
>struct DEV_LIST
>dev_list[] = {
> /* should leave these here */
> "debug", Ddebug, 0, "internal debug device",
> "extdebug", Dextdev, 0, "external debug device",
> "ranger", Dranger, 0, "range determination routine",
> /* selected for local system needs */
> "PS", Dpstscr, 0, "PostScript printer",
> "ps", Dpstscr, 0, "PostScript printer",
> "cps", Dcps, 0, "PostScript, color--8.5x11",
> Then, I recompiled the code. The next thing I did was editing
>$GRAPH/etc/PLOTTER file, and add printer name "laser" into it.
> After all these changes, I tried to create a simple compossit
>map and to use plot.sh ovm/* to send output to printer. However, I got
>an empty paper print out.
> Does anyone know what things I did wrong here? does MAPGEN4.1
> supports HPLaserJet 4M or not? What is the output format that program
>"plotter" used? Does it generates postcript as output?
> Thank you for any help in advance.
> PK Lin
> Tel: (617) 942-1655
> E-mail: pklin at cerf.net
I don't know what all the above is about, since I suspect most of it
is SCS value added on MAPGEN. But, my basic question is: does your
HPLaserJet support the PostScript language?
Gerald (Jerry) I. Evenden Internet: gie at charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
fax: (508)457-2310 N.Falmouth, MA 02556-1027
