Repost on Solaris
Evan Preston preston at malibu.dst.battelle.org
Mon Sep 26 09:07:19 EDT 1994
Hello fellow grass'ers:
This message is a repost from Friday (I'm not sure it made it or not).  Sorry
if this is a repeat, but I need to get a fix to the following problem:
I am having a problem with the display device (X0).  Specfically, the display
device does not refresh itself after being popped behind another window or
shrunk to an icon and refreshed.  Our system configuration is:
        SPARC 20
        SunOS 5.3 (i.e, Solaris 2.3)
        Motif 1.2.4
We are running the grass 4.1 (release 4) binaries for solaris.
I've messed around with the etc/monitorcap file, tried rebuilding the fifo's,
tried changing where the LD_LIBRARY_PATH environmental variable points to,
and tried running the various XDRIVER programs (XDRIVER, XDRIVER.fifo,
XDRIVER.n), but nothing seems to work.
Anyone have any suggestions?
P.S.  Where can I get a copy of the grass4.1 source code for Solaris?  Is it
the same as the SunOS source, but just compiled with different options?
Thanks,
        Evan
#     Evan B. Preston                            # Battelle                    #
#     phone:     614.424.3983                    # National Security Division  #
#     fax:       614.424.3776                    # 505 King Ave.               #
#     internet:  preston at malibu.dst.battelle.org # Columbus, Ohio  43201       #
