Some reflections on directories for temporary data in Grass
David Houlder david at dart.anu.edu.au
Mon Feb 20 18:02:25 EST 1995
> From grass-lists-owner at moon.cecer.army.mil Tue Feb 21 06:14 EST 1995
> From: Andreas Holz <Andreas.Holz at oi32.kwu.siemens.de>
> Subject: Some reflections on directories for temporary data in Grass
> Sender: grass-lists-owner at moon.cecer.army.mil
> Reply-To: grassp-list at moon.cecer.army.mil
> To: grassp-list at max.cecer.army.mil
> Date: Mon, 20 Feb 1995 14:24:11 +0100 (MEZ)
> X-Mailer: ELM [version 2.4 PL22]
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7bit
> Content-Type: text/plain; charset="US-ASCII"
> Content-Length: 1251
Hi all...
> 	What is the reason for a .tmp directory in the databases directory
> 	tree, is there something I've neglected?
My guess is that /tmp is not always very big, or may be used as swap
space, or may be implemented as a memory-resident filesystem. /var/tmp
is often bigger, but the best bet is probably to make your own tmp dir,
as grass does.
David Houlder			        Phone:	+61 6 249 4613
Geography Department	       	    (In Aust.:	(06) 249 4613)
The Australian National University	  Fax:	+61 6 249 3770
