Converting Arc 7.0.2 to Grass
DUNN JEREMY SIMON dunnj at polarbear.colorado.edu
Wed Jan 25 16:53:42 EST 1995
> > I have been trying to convert Arc/Info 7.0.2 vector files into GRASS raster files.
> > My previous attempts have yielded grass vector files, but I could not generate proper
> > topology even after using v.support.  It seems that the v.in.arc is properly converting
> > the lines, but missing the attribute values.  I would greatly appreciate if you could
> > send me the detailed procedure for conversion of Arc files into grass vector files.
> Rick Thompson-   Research Specialist          E-mail: rick at cast.uark.edu
> Center for Advanced Spatial Technologies      Telephone: (501) 575-8498
> Ozark Hall Rm. 12                             Fax: (501) 575-5218
> University of Arkansas
> Fayetteville, AR 72701
Hi there Rick ,,
My name is Jeremy Dunn. I was interested in your success rearding ArcInfo to
Grass (vector or raster) .Did you ever get hold of a step by step guide ?
I would be interested to get a copy og it if you did.
Thanks
Jeremy.
P.S. I'm basically trying to get some Mississippi Basin flood Maps into Grass.
Thanks
Jeremy
