comp. grass4.1, solaris2.4, gcc
    O. Hellwich
    olaf at sun7.photo.verm.tu-muenchen.de
    Wed Feb 28 07:00:00 EST 1996
Hi Augus,
this is our header file for solaris2.4 and gcc. I think it says
everything about compiler flags etc.
Olaf
CC                  = gcc
ARCH                = solaris
GISBASE             = /usr/local/bin/grass
UNIX_BIN            = /usr/local/bin
DEFAULT_DATABASE    = /dsun7d/grass/grass4.1/release/data
DEFAULT_LOCATION    = spearfish
COMPILE_FLAGS       = -O -fwritable-strings
LDFLAGS             = -s
XCFLAGS             = -D_NO_PROTO
XLDFLAGS            =
XINCPATH            = -I/usr/openwin/include
XMINCPATH           =
XLIBPATH            = -L/usr/openwin/lib
XTLIBPATH           = -L/usr/lib
XMLIBPATH           = -L/usr/lib
XLIB                = -lX11
XTLIB               = -lXt
XMLIB               = -lXm
XEXTRALIBS          =
TERMLIB             = -ltermlib
CURSES              = -lcurses $(TERMLIB)
MATHLIB             = -lm
#                   LIBRULE = ar ruv $@ $?
#                   LIBRULE = ar ruv $@ $?; ranlib $@
#                   LIBRULE = ar ruv $@ $?; ar ts $@
#                   LIBRULE = ar rc $@ `lorder $(OBJ) | tsort`
USE_TERMIO          = -DUSE_TERMIO
USE_MTIO            = -DUSE_MTIO
USE_FTIME           =
DIGITFLAGS          =
VECTLIBFLAGS        =
GETHOSTNAME         = -DGETHOSTNAME_UNAME
> Do I have to include any flags for gcc when the setup asks:
> Compiler to use [cc]:
> Are there any hints for installing gcc with Solaris 2.4?
> Agus
> Thanks
> Dr. Agustin Lobo
> Instituto de Ciencias de la Tierra (CSIC)
> Marti Franques s/n
> 08028 Barcelona (Spain)
> tel. 34 3 330 2716
> fax. 34 3 411 0012
> alobo at ija.csic.es
> alobo at eno.princeton.edu
