Distance computing (newbie asking help)
Ronald Wiemer rwiem at ARCHIS.NL
Wed Jul 17 08:00:00 EDT 1996
> Hi people.
> I started using GRASS 4.1 recently, and I think my problem is rather simple
> and must have been solved yet . This is a reason why I am asking now for
> some advices.
> My prob is :
> Given a vect file and a point, I would like to generate a rast file where
> each pix contains the minimal euclidian distance from this point to the set o
> f
> vectors defined by the vect file.
> Is there an already-existing function I could use ? In the other case,
> which primitives should I consider ?
I suppose you can also rasterize the vectors, use r.buffer and
invert the result.
Ronald Wiemer
R.O.B. / Archis
Kerkstraat 1
NL 3811 CV Amersfoort
The Netherlands
Tel: ++ 31 33 4634233
Fax: ++ 31 33 4653235
