grass compile errors on SGI
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Thu Jul 18 08:00:00 EDT 1996
On Jul 17, 11:00am, Robert White wrote:
> Subject: grass compile errors on SGI
> I am trying to build GRASS 4.1 on an SGI R5000 running IRIX 6.2 and
> come up with the following errors:
(text deleted)
> ld: ERROR 33: Unresolved text symbol "screen" -- 1st referenced by
> OBJ.sgi/mark.o.
>-- End of excerpt from Robert White
I am also trying to build GRASS 4.1 on an SGI but it is an Indigo2 Impact with
an R4400 CPU running IRIX 5.3. However, I did have the same problem and the
solution I used is as follows:
In the file mark.c there is a function called "get_point2" which calls the
"screen" function. The "screen" function is defined after the "get_point2"
function but it is declared inside the "get_point2" function. The problem is
that the declaration for the "screen" function is not recognized by the loader
since it is inside a function. To fix this you simply need to declare the
"screen" function before the "get_point2" function. The code would look
something like the following:
static
int screen();
static
get_point2 (east, north)
This fix solved the compilation error but I have not tested the programs yet.
Sincerely,
Jazzman (a.k.a. Justin Hickey)
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
