[GRASS5] i.ortho.photo fix
Markus Neteler
neteler at geog.uni-hannover.de
Fri Dec 17 10:22:06 EST 1999
Hi Bruce,
I think you mean i.ortho.photo/menu/main.c?
If so, please look at Gmakefile. The main.c is
obsolete :-) Only menuc. and run.c are used.
i.ortho.photo only contains the following bugs:
1. When setting the second (corresponding) passpoint
on toposheet reference (or whatever you use) in right
window, this point is only chown *after* accepting it
in terminal window ("look o.k.:" yes). This happens in
menu point (6) chosen from main menu.
2. You have to create an imagery group before using
i.ortho.photo, otherwise it
- either it does not start at all (case: you remove the last
active group)
- or it asks for an existing group
I think it would be better to create the group within the module
using menu (1).
Generally it is great that GRASS provides such an module.
Currently I am searching for a stereo analysis tool.
Best regards
Markus
On Thu, Dec 16, 1999 at 02:16:27PM -0600, Bruce_Byars at baylor.edu wrote:
> Look below:
> Between comments. Opening brace included but not the
> close brace.
> I_location_info (title, argv[0]);
> while(1)
> if (!I_vask_block_new (info, block, "EXIT"))
> break;
> new = !I_find_block (block);
> if (new)
> sprintf (buf,"\n%s - does not exist, ", block);
> G_warning (buf);
> continue;
> if (!I_vask_subblock_old (info, block, subblock, 0, ""))
> break;
> menu (block, subblock);
> return 0;
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 2393
max: 0
