[GRASS5] i.ortho.photo fix
Bruce_Byars at baylor.edu
Fri Dec 17 10:23:52 EST 1999
Doh! Yea, I am trying out the newest Sun workshop and
am using the source tracer. It flags all kinds of things, most
of which don;t mean anything. That slipped by me.
Bruce
Markus Neteler wrote:
> Hi Bruce,
> I think you mean i.ortho.photo/menu/main.c?
> If so, please look at Gmakefile. The main.c is
> obsolete :-) Only menuc. and run.c are used.
> i.ortho.photo only contains the following bugs:
> 1. When setting the second (corresponding) passpoint
> on toposheet reference (or whatever you use) in right
> window, this point is only chown *after* accepting it
> in terminal window ("look o.k.:" yes). This happens in
> menu point (6) chosen from main menu.
> 2. You have to create an imagery group before using
> i.ortho.photo, otherwise it
> - either it does not start at all (case: you remove the last
> active group)
> - or it asks for an existing group
> I think it would be better to create the group within the module
> using menu (1).
> Generally it is great that GRASS provides such an module.
> Currently I am searching for a stereo analysis tool.
> Best regards
> Markus
> On Thu, Dec 16, 1999 at 02:16:27PM -0600, Bruce_Byars at baylor.edu wrote:
> > Look below:
> > Between comments. Opening brace included but not the
> > close brace.
> > I_location_info (title, argv[0]);
> > while(1)
> > if (!I_vask_block_new (info, block, "EXIT"))
> > break;
> > new = !I_find_block (block);
> > if (new)
> > sprintf (buf,"\n%s - does not exist, ", block);
> > G_warning (buf);
> > continue;
> > if (!I_vask_subblock_old (info, block, subblock, 0, ""))
> > break;
> > menu (block, subblock);
> > return 0;
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 2393
> max: 0
length: 3271
max: 0
