[GRASS5] Re: license issues
Bruce_Byars at baylor.edu
Wed Dec 15 09:59:03 EST 1999
Markus Neteler wrote:
> Hi all!
> It seems we can proceed quickly here on the license issue
> (and we should!):
> >Proposed action: (from Bernhard)
> > - Move modules with licensing problem to src.license_problem
> > until we clarify it for the next releases
> Good idea. I start today.
This can and should be handled by a simple disclaimer and listing of the
modules.
> > - Replace code for the math routines.
> O.k. this is more work. Suggestion:
> - move critical modules to src.license_problem
> - replace critical library routines in a second step
> As this are only a few this may not be such urgent.
> > - Replace LZW with a better compression
> Suggestion:
> - Step1
> Replace the critical file
> src/libes/gis/lzw.c
> with another routine but *identical* funtion headers.
> This is not a nice programming habit, but can be done rather
> quickly. Then publish again to remove critical source code
> from internet.
> - Step2
> Replace the LZW-stuff totally. Needs more work.
> > - Replace gif with libungif for reading and add png as better
> > image format.
> Should be possible.
> > - Find the persons who contributed the code and ask in the
> > Case of MIPS, University of Illinois and DEC.
> Bill, Helena? Do you remember those CERL people? Did CERL have
> contracts which might be valid?
> Best regards
> Markus
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 1773
> max: 0
length: 2677
max: 0
