[GRASS5] Re: license issues
    Markus Neteler
    neteler at geog.uni-hannover.de
    Wed Dec 15 09:08:49 EST 1999
Hi all!
It seems we can proceed quickly here on the license issue
(and we should!):
>Proposed action: (from Bernhard)
>        - Move modules with licensing problem to src.license_problem
>                until we clarify it for the next releases
Good idea. I start today.
>        - Replace code for the math routines.
O.k. this is more work. Suggestion:
 - move critical modules to src.license_problem
 - replace critical library routines in a second step
   As this are only a few this may not be such urgent.
>        - Replace LZW with a better compression
Suggestion:
- Step1
 Replace the critical file
  src/libes/gis/lzw.c
 with another routine but *identical* funtion headers.
 This is not a nice programming habit, but can be done rather
 quickly. Then publish again to remove critical source code
 from internet.
- Step2
 Replace the LZW-stuff totally. Needs more work.
>        - Replace gif with libungif for reading and add png as better
>          image format.
Should be possible.
>        - Find the persons who contributed the code and ask in the
>          Case of MIPS, University of Illinois and DEC.
Bill, Helena? Do you remember those CERL people? Did CERL have
contracts which might be valid?
Best regards
 Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1773
max: 0
