[GRASS5] Re: license issues
Markus Neteler
neteler at geog.uni-hannover.de
Fri Nov 26 04:16:11 EST 1999
> ludcmp routine - finds inverse of matrix A
> lubksb routine - multiplies inverse of matrix A (from lucmp) by matrix b
> and returns matrix x (weights) in "b". =20
> I recommend removing these commands from the grass-beta source code
> until some rewrites these basic functions or the copyright situtation
> is clarified. I think the algorithms can be
> found in any good algebra book. Somebody just have to do it.
Hi Bernhard,
from my thesis work I can give you a routine for matrix inversion.
I have written a SVD (singular value decomposition) routine and
other routines. My other matrix operations are based on
"MESCHACH"
http://www.tu-freiberg.de/urz/soft/meschach.html
Meschach: Matrix computations in C
A lot of other stuff is at: NETLIB
http://www.netlib.no/netlib/master/index.html
-> fftpack
for: Fast Fourier Transform of periodic and other symmetric
sequences
-> itpack
for: Iterative Linear System Solvers
Jacobi method, SOR, SSOR with conjugate gradient acceleration
or with Chebyshev (semi-iteration - SI) acceleration.
Perhaps you could check the license issues here?
Thanks
Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1703
max: 0
