[GRASS5] manpages
Markus Neteler neteler at geog.uni-hannover.de
Sun Nov 21 14:42:17 EST 1999
Helena,
thanks for the man-pages. I have created a new package
with lots of updates from Lisa and one more from me (d.mon):
http://www.geog.uni-hannover.de/grass/grass5/html_grass5/html_grass5.tar.gz
> P.S. Markus - the Arcinfo and GRASS grid files are the same,
> all you need to do is to replace the header - r.out.arc and
> r.in.arc should just make it more convenient. We move
> the grid files between Arcinfo/arcview/grass all the time
> and it works fine and is very easy.
Sorry to insist, but this is surprising for me:
take a typical header:
ncols 101
nrows 161
xllcenter 4405975   -> lower left
yllcenter 5909975   -> lower left
cellsize 50.000000
NODATA_value -9999
Perhaps I am wrong that the order of cell rows in the file starts
with south row rather than north row in GRASS but on thursday I
had an ARC-GRID file which was flipped vertically after import.
I did not create this file but received it from someone else.
If I am wrong I will correct the r.out.arc of course. O.k. I will
check it with our local ARCView software. I did not take into account
that you could describe the lower left corner but start writing cell
values at upper left corner (someone missleading for me). I try
to find the ESRI reference.
Using GRASS is learning every day :-) (in positive manner)
Best regards
 Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1836
max: 0
