[GRASS5] New internal GRASS 5 beta5c
Markus Neteler
neteler at geog.uni-hannover.de
Mon Nov 8 13:23:39 EST 1999
Hi developers,
based on recent changes I have put a new beta5 into
the developer's directory here at Hannover.
What's better than before:
Fixes from: Jaro Hofierka, Luca Palmeri and Markus Neteler
- Makefile.in (Luca)
changed: install -d -m 755 -> mkdir -m 755
- src/mapdev/v.digit (Luca)
patched several files. Fixes problem with with curses
arises by the fact that a symbol is defined (#define CM CurrentMap)
This symbol 'CM' has another meaning in curses so this gives rise to a
symbol redefinition error. My patch simply changes CM to CMap everywhere.
- src/raster/r.cats/cmd/main.c (Luca)
r.cats, this fixes the fact that r.cats displayed the message "fp cells
need val arg" even when using int cells and the fact that the val arg
was never read.
- patches for Gmakefiles (Luca)
src/scripts/contrib/Gmakefile
src.contrib/CERL/raster/r.water.fea/src/inter/Gmakefile
src.contrib/CERL/raster/r.water.fea/src/programs/datafea/Gmakefile
src.contrib/CERL/raster/r.water.fea/src/programs/select_basins/Gmakefile
src.contrib/SCS/misc/m.lulc.USGS/Gmakefile
src.contrib/SCS/misc/m.strip99s/Gmakefile
src.contrib/SCS/raster/r.out.rlc/Gmakefile
src.contrib/SCS/raster/r.reclass.scs/inter/Gmakefile
due to compile problems on DUalpha
- src/sites/s.surf.idw/cmd/main.c (Luca)
fixes seg. fault on masked maps
- src/libes/g3d/* (Jaro)
src/include/G3d.h
new version
- src/raster/r.sun (Jaro)
added - new version with FP-support
- src/sites/s.in.ascii/main.c (Markus)
added #cat support for site_list (required for s.to.vect)
- src/display/d.sites/cmd/draw_point.c (Markus)
fixed d.sites with code from d.sites.qual
- updated all Gmakefiles: -lm -> $(MATHLIB) (Markus)
- src.contrib/CERL/raster/r.water.fea/src/*/Gmakefile
added several $(XDRLIB)
Cheers
Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 2252
max: 0
