[GRASS5] What is ESRCH?
Andreas Lange
Andreas.Lange at Rhein-Main.de
Mon Apr 17 17:29:17 EDT 2000
Markus Neteler wrote:
> Hi developers,
> due to user's request I found the following problem:
> The C-code defines ESRCH in some files:
> src/libes/raster > grep ESRCH *
> io.c: return errno != ESRCH;
> new_io.c: return errno != ESRCH;
> but a few compiler do not know this "ESRCH".
> How can I help/change ESRCH to some value?
> Regards
> Markus
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 855
> max: 0
Hi Markus,
ESRCH is POSIX.1 and defined in sys/errno.h on most standardized
systems.
On IRIX: errno.h:#define ESRCH 3 /* no such process */.
But many quirky systems have no or incomplete header-files installed.
But as Roberto Flor said, this is a problem of the system, no general
compiler or program error. You should verify that errno.h is included in
the source (#include <sys/errno.h>). Everything else is on the users
side.
cu
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
length: 2516
max: 0
