[GRASS5] New r.proj.new
Markus Neteler
neteler at geog.uni-hannover.de
Tue Aug 29 05:19:47 EDT 2000
Hi all,
Morten Hulden has done much work on r.proj:
"> Item: r.proj
> I've done some hacking on r.proj and I now have a patch that
> - aborts if the input map is outside current region
> - trims the output map to the current region or smaller
> - does not allocate more memory than necessary for projecting the
> overlapping parts of the input map and output region
> - aligns cell edges and centers of the output map exactly to those
> of output region
> - matches (unless changed explicitly) resolution exactly to that
> of output region
> - during overlap checks, passes cell centers to PROJ instead of
> edges (which are invalid in many projections, causing 'Error in do_proj'
> aborts)
> - allows projecting azimuthal, conical etc maps even if north is
> not upward or east is not rightward (no more 'north must be greater than
> south' or 'east must be greater than west' errors)
It is in CVS now.
Thanks, Morten!!
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
