[GRASS5] GRASS test suite started...
Markus Neteler neteler at geog.uni-hannover.de
Sat Aug 26 11:10:50 EDT 2000
Hi there,
just now I have added a preliminary script for
GRASS functionality testing into CVS.
"testgrass.sh"
Just run it. It is shell based and creates itself
a GRASS database/location/mapset with random name
and UTM projection.
The only test I have added up to now is the
"r.mapcalc -129 bug".
If you think, this makes sense, please extend the
script. What could be done:
* generate vector map, convert to sites and raster,
  convert back, compare.
* generate raster map, run statistics on it like
  r.stats, r.mapcalc, r.average, r.neighbors etc. etc
  and compare the results.
.. something like that.
Cheers
 Markus
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
