[GRASS5] Re: [adh@rachel.des.ucdavis.edu: Re: Projections request...]
Markus Neteler
neteler at geog.uni-hannover.de
Sat Aug 26 08:12:24 EDT 2000
Hi all,
the aea:Albers Equal Area
projection should support false easting/false northing
now (uploaded to CVS).
Below patch and another from Morten was required.
Many thanks to Eric and Morten!
Markus
On Mon, Aug 21, 2000 at 08:32:37AM -0700, Miller, Eric wrote:
> Markus,
> It seems to work. At least, the interface prompts for false
> northing/easting now when "aea" is selected for a new location.
> I haven't tried importing any data yet or projecting anything. I
> could make and send a diff to you this evening (California Time);
> I don't have CVS write access (probably a good thing [tm]). If you
> want to do it yourself, just paste in the following lines to
> src/libes/gis/geo_init.c about line 35:
> TABLE[AEA][X0].ask = 1;
> TABLE[AEA][X0].def_exists = 1;
> TABLE[AEA][X0].deflt = 0.0;
> TABLE[AEA][Y0].ask = 1;
> TABLE[AEA][Y0].def_exists = 1;
> TABLE[AEA][Y0].deflt = 0.0;
> I'll test out some data this evening and let you know if there were
> any problems.
> > -----Original Message-----
> > From: Markus Neteler [SMTP:neteler at geog.uni-hannover.de]
> > Sent: Saturday, August 19, 2000 4:34 AM
> > To: emiller at consrv.ca.gov
> > Subject: [adh at rachel.des.ucdavis.edu: Re: Projections request...]
> > Hi Eric,
> > if patched and tested successfully, could you please upload to
> > CVS or send a diff to me?
> > Thanks
> > Markus
> > Dipl.-Geogr. Markus Neteler * University of Hannover
> > Institute of Physical Geography and Landscape Ecology
> > Schneiderberg 50 * D-30167 Hannover * Germany
> > Tel: ++49-(0)511-762-4494 Fax: -3984 << Message: Re: Projections
> > request... >>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
