[GRASS5] New makefiles - work in progress, take 'em for a spin
Eric Mitchell
emitchell at altaira.com
Fri Aug 4 10:51:44 EDT 2000
Justin Hickey wrote:
> Hello Eric
> I was looking into running your Makefiles on our SGI and your instructions to
> change a few variables at the end of Platform.make say I need to provide
> something for the RANLIB variable. SGI does not have ranlib and the LIBRULE in
> our head file is:
> LIBRULE = ar ruv $@ $?; : $@
> as opposed to your LIBRULE which is:
> LIBRULE = ar ruv $@ $?; ranlib $@
> I have no idea what ranlib does or what the equivalent command on SGI would be.
> Do you have any ideas as to what I should set RANLIB to? Should I leave it
> blank? It appears that the LIBRULE does not replace it with anything.
ranlib restructures the library for more efficient random
access. "RANLIB = true" should do the trick for platforms
that don't have/require ranlib.
> Also, why can't GRASS_HOME be GISBASE?
Work in progress taken from other project that uses NAME_HOME
instead of NAMEBASE. The GRASS_HOME references should be changed
to GISBASE.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
