[GRASS5] Compile Grass 5 on Win 32
John Huddleston jhudd at lamar.colostate.edu
Tue Aug 1 08:25:47 EDT 2000
Mike,
The June 27, 2000 ZIP file for Grass5 binaries
assumes you are installing it under /usr/local
so it starts with grass-5.0b.
It is not hard-coded to /usr/local because some
people have no space on the C: drive and they
can create a mount point or a symbolic link
to another drive.
The problem with the unknown operand looks
like you are either not using a bash or sh shell
or you do not have /bin.   Do the command
`ls /bin/sh.exe`   and `cygcheck -v -s -r` and
send the output to me.
See the previous email to Brad on how to mount
the /bin directory if it does not exist.
John Huddleston
----- Original Message -----
To: grass5 <grass5 at geog.uni-hannover.de>
Sent: Tuesday, August 01, 2000 5:32 AM
Subject: [GRASS5] Compile Grass 5 on Win 32
> Hi all.
> Three problems.
> 1. How do I install the Win32 Grass beta binaries from 27/5/00 so that all
> the links in /usr/local/bin are present.   The zip seems to be smaller
than
> last time too - 26 Mb instead of 44 Mb.
> 2. The configure script needs to be changed so that it also looks for
> xdr_int in librpclib.a under Cygwin.
> 3. When I do a make install, I get:
> test -d /usr/local/grass-5.0b || mkdir -p -m 755 /usr/local/grass-5.0b
> test -d src/CMD/next_step || mkdir -p src/CMD/next_step
> UNIX_BIN=/usr/local/bin SRC=`pwd` MAKE=make NAME_VER=`cat src/CMD/VERSION
> head -1 | sed 's/\..*//'` GISBASE=/usr/local/grass-5.0b
> MACHINENAME=`uname -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
> [: 0: unknown operand
> /bin/sh `pwd`/src/CMD/generic/is64bit.sh
> test: 8: unknown operand
> echo "Now proceed with make install"
> GRASSSRC=`pwd`/src GMAKE=`pwd`/src/CMD/gmake5.0 MAKE=make /bin/sh
> src/CMD/generic/GISGEN.sh
> make: *** [do-install] Error 1
> Any ideas?
> Cheers
> Mike Thomas
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
