[Re: [GRASS5] GRASS in Windows95/98]
BRADLEY HARRISON
bradley.harrison at usa.net
Tue Aug 1 07:41:29 EDT 2000
I figured out part of my problem in opening grass is that I have to
configure it and I have not gotten the configuration program to work properly
yet..
As far as the rast.to.vect command I may have the command incorrect, but
what I am attempting to do is to convert images of architectural drawings of
an archaeological site that are at this moment in Tiffs into vecter dxf files.
I am certain that this was done in GRASS when I did it as a student. I hope it
wasn't in another program such as Idrisi or such.
Thanks
Brad
"John Huddleston" <jhudd at lamar.colostate.edu> wrote:
> Since XGrass was removed you do not need X11R6.4.
> Are there Fortran components in Grass? I can't remember
> off hand. If you develop then yes, otherwise no.
> Help me out with the rast.to.vect command. I cannot find
> this in the Grass5 source. What command are you looking
> for?
> John
> ----- Original Message -----
> From: BRADLEY HARRISON <bradley.harrison at usa.net>
> To: <grass5 at geog.uni-hannover.de>
> Sent: Sunday, July 30, 2000 1:05 AM
> Subject: [GRASS5] GRASS in Windows95/98
> Do I still need all the other bits such as g77 and X11R6.4 to get GRASS
> to
> work or all I need is the preconfigured downloads?
> For the moment all I need is to get the rast.to.vect to work. Though I
> would like to get a DEM going, but without a monitor it may not be much
use.
> yours
> Bradley Harrison
> John Huddleston <jhudd at lamar.colostate.edu> wrote:
> > hi Bradley,
> > Many of the grass data manipulation functions
> > are available for windows. The monitor (or
> > display) is not yet available. I have not tried
> > the Tcl/Tk interface yet though.
> > You will have to install either the older Cygwin
> > B20.1 distribution or the newer version 1.1.2
> > in order to get the "unix" commands and DLLs
> > required to run grass under Windows.
> > The ZIP distribution looks for executables under the
> > /usr/local/grass-5.0b area. Forward slashes only make
> > sense when using Cygwin.
> > John Huddleston
> > If you want to unsubscribe from GRASS Development Team mailing list write
> to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> ____________________________________________________________________
> Get free email and a permanent address at http://www.netaddress.com/?N=1
> to:
If you want to unsubscribe from GRASS Development Team mailing list write to:
